friends help me i have year 2005 toyota corolla.suddenly indicates ABS light on running.i replaced original break pads,checked brake oil.but no change.want your idea
best thing is to do is take your car to the agents and run a full diagnostic check up and figure out what is the problem is with abs. it maybe a abs sensor gone wrong
THANKS
Probably something wrong with the abs sensor on a wheel.
Take a look at each wheel and see if there are any loose connections before you run a diagnosis.
This should help you a little bit more, also read all the comments in the video if you can. Many similar problems have been solved here.
thank you my friend
