Fuel System Cleaners - Bg 44K Vs Chevron Techron
Hi All,
I'm looking to use a good fuel system cleaner for my Nissan March BK-12. I have few questions. need your help here.
have any of you used any of the two above?
Are these better compared to "Wurth" or "valvoline" Fuel system cleaners?
Is BG 44k will be too powerful for my BK-12?
Is there any place to buy Chevron Techron in Sri Lanka?
looking forward for your feedback.
3 answers to this question
Hi All,
Where can you buy BG Products in Sri Lanka. I am looking forward. I have not used Valvoline.
Hi varuna,
Just check
http://lexuslanka.com/
Lexus Trading (pvt) Ltd.
No. 26, Bodiraja Mawatha, Rajagiriya,
Sri Lanka
By the way what is your experience with Wurth...?
My experience is Pre Ignition knocks at low RPM under load. This is mainly due to carbon deposits on piston crowns. Wurth did not help here. By the way, Wurth is a very good brand which is professional grade. If you just need injector cleaning this would be good.
For Injector cleaning, the other method is Ultrasonic. I got the same done from D*** recently and they did a decent job. From my research, this is the best way to do Injector cleaning. But mind you this does not clean the intake, valved, piston heads and piston chamber. Usually you need to clean all these after sometime.
Thank you for the BG tip, I will contact them.
