Hi ,
suddenly my nissan car RPM meter malfunctioned now its not working. i repaired AC recently and that guys put some water to radiator after their works in order to make the heat down. water droped to the radiator fan and it sprayed to engine. i am worring was that the reason for this meter guage malfunction. is there any sensor nearby to detect rpm?
if u have any idea plz let me know..
car is nissan sunny FG 10 bluebird sylphy 2001
Hi ,
Hi Dumi##a
Spraying a little water will not an issue i guess , If your car is petrol RPM Signal wire run through your ignition coil to the guage
if it is Diesel it from the alternator, Possibly while making the AC He would have pulled that wire without knowing could be the reason
definitely it is a wiring issue don't worry can be made easily if you go to auto electrician :)
thanks
regards
sumith
Edited by Sumiya
Hi Dumi##a
thanks
regards
sumith
thanks brother. this is a petrol car. and i was lookin when they work. but i didnt notice that they pull some wire.. :S but i will put car to an electrition. thanks for the comment.
Hi ,
You mean first it showed some incorrect value and now it's totally not working ?
