Recently i brought Nissan Fb12 car(Trad Sunny).Heat Meter of it Indicate half passion when drive, is it Normal Condition of that car or is it Indicate Overheating.
Hi tmaknishantha
It is normal, some cars having a special indicator in which location it has to sit when normal driving condition,
if you don't have something like it is normal condition :)
thanks
regards
sumith
Half is the normal position on most cars. If you are worried that your cars temperature reaches half too soon its not because of overheating, engines require an optimum temperature to run therefore when you cold start an engine it wont kick in the cooling mechanisms like the radiator fan etc until the engine has reached its optimum temperature. So as long as your meter doesn't go above the halfway mark (specially on long journeys) your fine.
Where was it before?
MINIACE
