My blower stopped working.It blows no air at all.Don't get any error message on the display.
Tried to check the fuse box, but the box cover offers no reading help.Any clue ?
it can be anything from a blown fuse to a loose connection in the wiring or even a busted blower motor.
Harshan might be able guide on the fuse layout. In most jap cars, the blower fuses are located on the passenger side kick panel and not on the main engine bay fuse box
D8 or D9? Manual a/c or climate control ?
Most of the times the issue of sudden hiccups in blower motor due to loosen main connector which can be found once you remove the black color panel under the dash on passenger side. Usually a yellow/ ash color connector.
It's a D9 with climate control.
I'll check up the main connector and let you know.
The main connector it is!
Found it ,retightned it and the air is back.
Thanx Harshan,ripper and shehan,it's good to have you guys around.
Anyway if I come across with an AC/electrical issue with this car,is there any recommended place anywhere between Colombo and Chilaw?
Have heard about RS auto in Kandana,are there any more places around?
Given the contact details of this place couple of times in this forum. Can recommend and his main expertise on a/c and electrical
Aruna Amarasinghe - Throve Automobile Engineering 773 841 315
