Fb15 Service Stations
sadamal
Then, suggest to go to the agents and get everything checked properly.
Get your car scanned for sensors and ECU faults (if you doubt your car has any) and tuned up. Change the ATF and Engine Oil, do a full fuel system clean up, Clean the air flow system, If need, clean the injectors, check the plugs, Check the sensors (scan will give you the results of the sensor and injector conditions).
After this, keep your service intervals consistent at the right time, you will get the return in a positive way.
Good Luck!
Edited by slcamel
  On 10/28/2011 at 8:29 AM, sadamal said:
I bought the car recently so I think its better to do all the things above mention. Also I need to changed ATF oil as well. Your kind suggestions are welcome. :)
What is your location?
Good Luck!
:) Thankx for sharing your valuble thoughts
