October 31, 201115 yr Can somebody Pls tell me the fuel tank capacity of Nissan N16 Ex Saloon car? Thanx
October 31, 201115 yr AjithC if your car is 1796cc 2002 model, my late sis had same car, fuel tank capacity was 50 Liters but you can still add another 1 liter or more till you fill up to the fuel cap. Sylvi Wijesinghe.
October 31, 201115 yr Author Thanx for the information, But I couldnt found N16 in above document (I searched under SUNNY), I really need this information to fill up my official document, So some body pls verify me whether 50l is the fuel tank capacity for N 16 Auto car.
October 31, 201115 yr Sylvi is correct. It should be 50 liters. In above link provided by 'tglk' you should check under 'Bluebird sylphy'
November 1, 201115 yr but you can still add another 1 liter or more till you fill up to the fuel cap. But do you recommend this?
November 2, 201115 yr SeanD, I don't recommend this. I stop pumping fuel at auto cutoff by the fuel station pump some times few rupees to round up the fuel bill. I do some times when I do a long run for checking of fuel consumption. if you do it on hot climate specialy during the April to August there can be fuel will come out of the tank fuel cap if you do not run long to cosume fuel this is my experience with the new Automobiles. Sylvi Wijesinghe.
