Converted (Petrol To Diesel) Kr42 Price, Procs And Cons
  • Replies 61
  • Views 31k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • JadeyBlitzen
    JadeyBlitzen
    On a side note here are some of the parts our noah builders ignore Rear coil springs front and rear differentials (on some models) rear axle rear bump stops 3rd row seat mounting brackets ABS (o
  • JadeyBlitzen
    JadeyBlitzen
    price depends on your yom, registration, which engine you used (2c,3c,3c turbo, 3c turbo ic), if you used original parts or modified existing parts. no cons if you used original cr parts for the modi
  • JadeyBlitzen
    JadeyBlitzen
    finished last feb. took 3 months. dont have many pics of the build but will post pics of what was changed like before n after. here's a pic I took while we were holidaying in chilaw
but i am not planning to change,
Front shell
front bumper
head light set :sad-smiley-066:
also i am planing to check about differential set and coil springs. but i don't think Cr42 and Noah have differences.
hey....to get a good look ,u hv to change normal lights to Cyrstal lights...and change the front bumper with fog lamps....
it will increase the value of da van.....
U can buy Crystal light set for around 35 000..
Nilantha
Where did you buy below items?
I asked one mechanic in Wannappuwa and he siad fully interior change need 2.5 lacks.
these days i am doing Noah conversion. i will put you that all in details. but it will take few days. because it is in progress.
i have CR42 1997 model original diesel Manual flat roof four door model. i am planning to dress it up with 1999 noha kit.
i already bought,
1. Noah interior set including roof cover, side boards, carpet, rear AC unit, room lights, seat belts, foot boards, door bee-dings and etc. 60,000/-
2. Original complete wiring harnesses - 10,000/-
3. CR42 Dashboard, including inner steel bar, front AC unit with climate controller - 20,000/-
4. complete Steering Column - 8,000/-
5. Rear door - 20,000/-
6. Front power door set with double power nickle power mirrors - 20,000/- ( i have two complete door sets. if some one want i can give you other set for 20,000/-)
7. left Side sliding power door - 8,500/-
8. Noah seat set 60,000/-
9. 7C Ac compressor - 8,000/-
10. complete Noah side glass set 15,000/-
11. CR41 original fog light set 7,000/-
12. Alow wheels with Goodyear tires 62,000/-
Tinkering works done buy one of my friend. but i gave him 20,000/-
my other friend going to do full paint i will put how cost it later.
Front shell
front bumper
i will post all pictures step by step later.
Edited by thusithasam
  • Author
i already bought,
Front shell
front bumper
really appreciate your post. shall know where did you buy those things and contact no of person who make changes to the vehicle.
i bought Cr41 crystal light set for 15,000/- including 2 head lights and 2park lights. i already bought original fog light set. i will post pictures later.
i replaced the CR 42 crystal light set....
what is 4.3:1 or 4.1:1? i will go to the shop that i buy Noah set and i will find out about this things.
sorry I meant to say they come with either 4.3:1 or 4.1:1 final drives. no point in asking the shop people. they won't know sh*t about diff ratios. I had a jolly good time matching 4.1:1 diffs for my 4wd
please explain if you have time, what is the meaning of 4.3:1 or 4.1:1 ?
final drive is the gearing system you get in the differential and it further cuts down the gearing after the gearbox. so when a prop shaft turns 4.3 times in your cr41 the wheels turn once. its this ratio I cant recall from the top of my head. anyway don't worry about this since you are sticking to the g52 gearbox.
from where you get this information. i don't think this is correct. check this out. if have difference with CR42 and SR40 they show it here.
http://www.megazip.ru/ru/auto/toyota/view/475/4313/42601/408740#g408967
but they not mention any difference on differential.
you check, they have mention on this website difference between CR41 dashboard and CR42 dashboard. so if have differences between Cr42 and SR40 differential they have to have show it here.
http://www.megazip.r.../408740#g408967
dude try toyodiy.com/parts
Hood
Side upholstery
I have other pictures. tel me how to upload. i have used over quota.
try to fix the Noah exteior parts as well, cause one thing i noticed in a van that was converted was that it felt too light for the power of the turbo engine, when i was doing around 80+ kmp/h it felt like the van was loosing control cause it didn't have enough weight
  • Author
Hood
Side upholstery
i think. its because of your image size.open images with paint and go to -> save as ->name.gif format. and save.
I have 5 door vehicle.how it fits with interior set?? and i need to buy power mirrors? does remote control power mirrors available? n please let me know the best place to buy.
5Door vehicle not support to Noha conversion. i have 2 double power mirrors if you want tel me
Relay unit.
AC control switch set.
Edited by Nilantha
Central door lock control unit
Side door closer unit
Edited by Nilantha
Wire harnus
Rear AC unit
Edited by Nilantha
Front side panel.
Rear side foot board.
Edited by Nilantha
Steering Column
Front AC control unit
Edited by Nilantha
