Hi guys. I observed that my ATF oil level has gone down bit. Z it ok if I jst refil it till I get my next service done?? I cnt remember the brand I used earlier. Wld it b an issue if use anothr band? (sch as M_bil) My car is a Nissan Fb 14
Recommended ATF type for FB14's is Dextron III or Mercon. I think in Sri lanka Dextron III is the type that is widely used since it is easy to find. So, if the ATF type is equivalent to Dextron III it won't matter what brand you use.
By the way, i guess your ATF level is not too low. If it's too low, better to check for any leaks also :) .
if you find you have a leak, check the breather pipe isnt being crushed by something as this can be the cause of a leaking gasket so if the breather isnt sorted you will only be replacing the same leaking gasket further down the line.
