January 28, 201214 yr Members, Diesel engines some start without preheating in the morning. some need to heat once or three times. This happens due to low compression. Sylvi Wijesinghe. gotta disagree here. low compression is one reason for poor morning starts but not the only one. it can be anything from poor heater plugs, poor ignition timing (retarded ignition at the pump), bad fuel filter etc for instance...on my ford diesel recently replaced all four injectors, air-oil-fuel filters after i start noticing a bit of black smoke and somewhat poor starting in the morning. Truck used to start without heating the moment you crack the motor up. Later i had to crank 2-3 times even after heating up. heater plugged checks out ok, fuel filter was replaced with one with a manual pump cos originally it didn't come with a manual pump Even with new filters, injectors...still it doesn't start the first go in the morning. engine doesn't burn oil and had been rebuilt at 200k. its less than 40k over that figure at the moment I too am quite foxed why i still have morning starting issues. leaning towards ignition being a bit retarded.
January 15, 20188 yr Hi friends! I have a Nissan serena VX 58- Van. This vehicle having a problem that frequently defective of one glow plug. When I inspect after removing, I observe two plugs have oil around the tip. Is it possible? Please clarify whether there is a relationship of this oily tip for defect of glow plugs. ย Edited January 15, 20188 yr by saliya sudusinghe
