I have a 2005 model Grand escudo.
pls explain how 4wheel operation in touch system .
what to do and not to do's. difference between 2H,4 H & Neutral etc,
can i switch over to 4 wheel while driving.?
i cannot interchange 4H & 4L ( a beep sound heard,nothing happens)
how to release from 4 wheel operation? have i to stop the engine.?
Not sure about the touch system, but generally -
you can change from 2H to 4H whilst on the move, but at speeds of no more than about 40 or 50 kmh.
Generally to go from 4H to 4L you need to stop the vehicle and have it in nuetral
similarly to come out of 4WD
- from 4L - stop the vehicle and put into nuetral before switching
- 4H to 2H can be done on the run.
There is normally also a recommendation that when you come out of 4WD (especially 4L) you should reverse the vehicle in 2WD for a couple of meters to completely free the hub.
