defendertdi Posted February 17, 2012 Posted February 17, 2012 Hey, Post your experiences and thoughts of N2(99.5%) in Tyre I filled the Tyre set with N2..it seems bit difference to me..when driving on rough roads where carpet is worn out.........Bt i dnt knw Actually N2 in Tyre is da Reason or not.......... Composition of Atmosphere..... Source-- WIKI Nitrogen (N2) 780,840 ppmv (78.084%) Oxygen (O2) 209,460 ppmv (20.946%) Argon (Ar) 9,340 ppmv (0.9340%) Carbon dioxide (CO2) 390 ppmv (0.039%) Neon (Ne) 18.18 ppmv (0.001818%) Helium (He) 5.24 ppmv (0.000524%) Methane (CH4) 1.79 ppmv (0.000179%) Krypton (Kr) 1.14 ppmv (0.000114%) Hydrogen (H2) 0.55 ppmv (0.000055%) Nitrous oxide (N2O) 0.3 ppmv (0.00003%) Carbon monoxide (CO) 0.1 ppmv (0.00001%) Xenon (Xe) 0.09 ppmv (9×10−6%) (0.000009%) Ozone (O3) 0.0 to 0.07 ppmv (0 to 7×10−6%) Nitrogen dioxide (NO2) 0.02 ppmv (2×10−6%) (0.000002%) Iodine (I2) 0.01 ppmv (1×10−6%) (0.000001%) Ammonia (NH3) trace Quote
0 nano31 Posted February 17, 2012 Posted February 17, 2012 As you already know normal air means 78% of N2 so filling with 99% N2 means just adding 21% of N2 instead of O2 (bit heavy). So I dont think you can feel any real difference in normal driving conditions. May be you are feeling some placebo effects! 1 Quote
0 Hiran_j Posted February 17, 2012 Posted February 17, 2012 I have been using N2 recently. The only good reason is : They fill N2 more generously than normal air (in fuel stations) When they fill Normal air, they do it carelessly ... Quote
0 Watchman Posted February 17, 2012 Posted February 17, 2012 This has been discussed to great detail and believed to be useless for the money you spend. Do a search if you want details Quote
0 Crosswind Posted February 17, 2012 Posted February 17, 2012 (edited) On 2/17/2012 at 7:02 AM, defendertdi said: I filled the Tyre set with N2..it seems bit difference to me..when driving on rough roads where carpet is worn out.........Bt i dnt knw Actually N2 in Tyre is da Reason or not.......... It's called placebo effect Edited February 17, 2012 by Crosswind Quote
0 The Don Posted February 17, 2012 Posted February 17, 2012 Nitrogen is only useful in performance application where normal air is too unstable (for example the Nissan GTR where the tyres are subjected to massive forces due to sudden changes of direction). 1 Quote
0 varunatech Posted February 17, 2012 Posted February 17, 2012 On 2/17/2012 at 2:11 PM, The Don said: Nitrogen is only useful in performance application where normal air is too unstable (for example the Nissan GTR where the tyres are subjected to massive forces due to sudden changes of direction). Spot on........ Quote
0 defendertdi Posted February 17, 2012 Author Posted February 17, 2012 On 2/17/2012 at 8:45 AM, Crosswind said: It's called placebo effect may be........ Quote
0 maheshw Posted February 17, 2012 Posted February 17, 2012 forget about that your drving with N2. then you will not feel any diffarance. Quote
0 osanda19 Posted February 17, 2012 Posted February 17, 2012 ya..no change for me tooo..its hard to search n2 filling points in outstation.then i changed 2 normal air Quote
0 whmsujith Posted February 18, 2012 Posted February 18, 2012 I am also using N2 nd only advntage I have is the drop of tyre pressure for a month is minimal (about 1-2 units) compared to normal air. Quote
0 Crosswind Posted February 18, 2012 Posted February 18, 2012 On 2/18/2012 at 2:14 AM, whmsujith said: I am also using N2 nd only advntage I have is the drop of tyre pressure for a month is minimal (about 1-2 units) compared to normal air. If you are losing pressure (even 1-2 units a month) something could be wrong with your tires/valve and/or rims. This is irrespective of what you pump in the car. You might as well get them checked. For example, my Focus has not lost pressure, even with plain old air, for over 4 months now but the older car which has a minor dent in the rim tends to lose about 1-2 units a month. Quote
0 SeanD Posted February 18, 2012 Posted February 18, 2012 On 2/18/2012 at 2:14 AM, whmsujith said: I am also using N2 nd only advntage I have is the drop of tyre pressure for a month is minimal (about 1-2 units) compared to normal air. If you're dropping that kind of pressure, I suggest you get a new set of wheels Quote
0 NPP Posted February 18, 2012 Posted February 18, 2012 On 2/17/2012 at 4:36 PM, osanda19 said: ya..no change for me tooo..its hard to search n2 filling points in outstation.then i changed 2 normal air once four of us went on certain trip to yapauwa, kurunegala and some other places.... looked for a fuel station to pump air and found a tyre shop which had ONLY nitrogen :S Quote
0 whmsujith Posted February 18, 2012 Posted February 18, 2012 On 2/18/2012 at 10:42 AM, Crosswind said: If you are losing pressure (even 1-2 units a month) something could be wrong with your tires/valve and/or rims. This is irrespective of what you pump in the car. You might as well get them checked. For example, my Focus has not lost pressure, even with plain old air, for over 4 months now but the older car which has a minor dent in the rim tends to lose about 1-2 units a month. On 2/18/2012 at 12:20 PM, SeanD said: If you're dropping that kind of pressure, I suggest you get a new set of wheels The thing is that 5 weekdays car is parked in my gurage and only in weekend I use it. Tyres & valves are new (6000km only) but as you mentioned may be a issue with rims. But after I swiched to a N2 see a difference, lesser drop for a month. Quote
0 jdnet Posted February 18, 2012 Posted February 18, 2012 i'm thinking of starting a business that sells air compressors that produce the perfect combination of gases to fill into tires. On the ads it will say; "N2 with added O2 for extra performance." The mix will be 78% nitrogen and 21% oxygen. 3 Quote
0 jdnet Posted February 18, 2012 Posted February 18, 2012 (edited) === Edited February 18, 2012 by jdnet Quote
0 NZer Posted February 19, 2012 Posted February 19, 2012 Heard of selling Sand to Arabs Snow to Eskimos and Air to Fools? Quote
defendertdi
17 answers to this question
