Sensor Carb On Hornet's
Biker boy
  On 3/14/2012 at 8:09 AM, Biker boy said:
hi,
Any information on the below will be much appreciated :)
What exactly a Sensor Carb system do on a Hornet 250cc chassis 130. ??
I'm not 100% sure about hornets but even on my honda XR..you get a throttle position sensor. aka. TPS.
From what i understand, it's just to tell the ECU to control the spark timing/duration etc.
Nowadays quite a few bikes are having fuel injection... these don't have carbs but have a miniature version of a vehicle injection system.
  • 11 years later...
It's called as the throttle position sensor (TPS) used to monitor the butterfly spindle/throttle valve's position on your carb or throttle body (It's integrated with your engine control module) to response how much the air gets in, to keep the engine running in idle without getting stalled and helps in cold start
