Biker boy Posted March 14, 2012 Posted March 14, 2012 hi, Any information on the below will be much appreciated What exactly a Sensor Carb system do on a Hornet 250cc chassis 130. ?? Quote
Ripper Posted March 14, 2012 Posted March 14, 2012 hi, Any information on the below will be much appreciated What exactly a Sensor Carb system do on a Hornet 250cc chassis 130. ?? I'm not 100% sure about hornets but even on my honda XR..you get a throttle position sensor. aka. TPS. From what i understand, it's just to tell the ECU to control the spark timing/duration etc. Nowadays quite a few bikes are having fuel injection... these don't have carbs but have a miniature version of a vehicle injection system. 1 Quote
Cyclist Posted March 15, 2012 Posted March 15, 2012 http://wiki.answers.com/Q/What_the_honda_hornet_Sensor_carb This says its about a heater in the carb, which i dont believe! I agree with Ripper here. Quote
Cyclist Posted March 15, 2012 Posted March 15, 2012 Some more info here about hornet from SL http://www.elakiri.com/forum/showthread.php?t=1075104&page=5) Quote
Aqeel Ahamed Posted January 29, 2024 Posted January 29, 2024 It's called as the throttle position sensor (TPS) used to monitor the butterfly spindle/throttle valve's position on your carb or throttle body (It's integrated with your engine control module) to response how much the air gets in, to keep the engine running in idle without getting stalled and helps in cold start Quote
