guys what is the price of a good fb14 distributor.Can you recommend me any good places to buy around colombo.tanx
Distributor leaks oil.can this error code be recovered by putting a o-ring??or is this ecu error comes because the crank sensor failed permanently?
Edited by hhrxz
no one time to reply. hema eakama RehanaA passe duwanawa :sport-smiley-004: :sport-smiley-004: :sport-smiley-004: :sport-smiley-004:
Except for you who was trying to sell stuff on this thread, huh?
Try the Watte area in Panchikawatte if you are looking for a used one. Depending on the issues with your distributor getting it repaired or getting a brand new one should also be considered. If memory serves me right pioneer motors in Panchikawatte is a good place for Nissan spares.
i don't want to sell any thing here. he is asking prices. i just tel him prices. i no have distributors to sell.
Edited by Nilantha
tanx for the info bro.crank sensor has failed.Ecu giving an error.Can the sensor only be replaced here?
tanx for yr help.ill upload a pic and contact u.
Ahh how sad. None of your hero friends replied ne? pawww ane.
bro i have no personal issues with u.and i dnt know any friends here personally.
I bought one of these for my FB14 from U.S. Motors, Dehiwala few years ago. Can't remember the exact price but it was around Rs 6000 i think. Used it for more than an year until i sold the car. As The Don has mentioned, you should try to repair it before replacing. There are auto electricians who can fix them.
tanx for your info.yesterday i went for a tune up and my car gives a faulty crank sensor code.and i found some oil leak under the distributor cap.Can this error code occur because of a bad o-ring?
Well it depends on if the distributor and the sensor come as 2 units. I think the crank sensor developing issues in Nissan's is quite common and the first thing to do is to clean the sensor thoroughly, replace it and see if it resolves the issues. Yes a faulty o-ring can cause a sensor to fail if its not usually immersed in oil. It sounds like at present you are looking at options and cost. Take the car to a good mechanic, do the easy things first before looking at replacing things like the distributor.
yes thanks ill first give it a try replacing the o ring.car doesnt give any symptoms.its runs fine.all that i noticed was a reduction in fuel consumption.
Edited by hhrxz
Yeah, replace the oring, and clean all associated components thoroughly, reset the ECU and see if the readings go back to normal.
