Bg5S-323 Gearbox Oil Leak
Nimz77
im new to the vechial stuff and also this is my first post in autolanka.im having issue with my mazda bg5s-323 (1992 YOM-1500cc).i saw some gear oil leak on speedometer cable connector(conneting point to gearbox).
i did replacement for overring also.but still oil leak can see.please advise.(my speed meter working)
Appreciate if you guys can give me your advise ..
Its difficult to give advice because we can't quite see where the leak is nor the success of the original repair. Did the leak stop at least momentarily when the o-ring was replaced?
It could be that the leak is from somewhere else but just dropping onto the speedometer cable. Take the car to a good mechanic because it doesn't sound like a complicated problem to solve.
Thanks lot for your answer.yes.leak was stop(75%) after replace o-ring.im from nugegoda.do u know any good place to check my car.?i will attach picture of gear leak point tomorrow.also i want to check my fuel usage?is there any place i can get tune EFI.?near nugegoda...?where i can get used parts(such as rack -full kit,door locks) near nugegoda.
