August 13, 201214 yr Hey guys, With time my motorcycle's engine block is not as shiny and nice as it would be on a brand new bike. So I was thinking of brushing this up. Mine's a air-cooled bike, so it has those fins/gill for cooling, and hence you cant easily reach all areas or give it a thorough cleaning. with a conventional cloth/soap approach. And the non-glossy surface means stains don't come off easy (photo below). Currently I use a bike shampoo I found at a local hardware shop that's quite good for a general wash and at removing chain lube splatter the rims, spocket cover and other areas that you get unwanted oily substances on. So my questions; 1- What soap (or polish or similar substance) can be used for removing such stains. 2- How do you guys reach inside the cooling gills of the block?
August 13, 201214 yr there I see some salt/rust foamation sort of marks on the fins. Therefore I doubt whether you can remove these using cleaning / degreasing liquids. Try some of those wheel / alloy cleaning products which createse a foam and allows you to brush off dirt. as for the equipment, http://www.google.com/imgres?q=wheel+cleaning+brush&um=1&hl=en&sa=N&rls=com.microsoft:en-us:IE-SearchBox&biw=1525&bih=709&tbm=isch&tbnid=VfWiaRk3hJJrOM:&imgrefurl=http://www.detailsupplyonline.com/product_info.php%3Fproducts_id%3D143&docid=5wszvm5aDLq3VM&imgurl=http://www.detailsupplyonline.com/images/soft_spoke_brush.jpg&w=500&h=499&ei=4oIoULmEE8jorAfA4IDwDA&zoom=1&iact=hc&vpx=403&vpy=366&dur=3558&hovh=224&hovw=225&tx=90&ty=239&sig=112336397215381866723&page=1&tbnh=166&tbnw=152&start=0&ndsp=20&ved=1t:429,r:14,s:0,i:119 http://www.google.com/imgres?q=wheel+cleaning+brush&um=1&hl=en&sa=N&rls=com.microsoft:en-us:IE-SearchBox&biw=1525&bih=709&tbm=isch&tbnid=qIjn_dnU9LZjFM:&imgrefurl=http://chemicalguysusa.blogspot.com/2012/05/wheel-woolies-wheel-brushes-3-piece-kit.html&docid=DPgWsuuDgc5xBM&imgurl=http://i165.photobucket.com/albums/u79/chemicalGuys7/Wheel%252520Woolies%252520Wheel%252520Brushes/WheelWooliescarcarewheelcleanerbrushesbrush.jpg&w=1022&h=593&ei=4oIoULmEE8jorAfA4IDwDA&zoom=1&iact=hc&vpx=436&vpy=289&dur=232&hovh=171&hovw=295&tx=125&ty=114&sig=112336397215381866723&page=2&tbnh=111&tbnw=191&start=20&ndsp=28&ved=1t:429,r:23,s:20,i:212
