FastCar Posted August 26, 2012 Posted August 26, 2012 I am currently experiencing an engine miss in my Montero. Could you please recommend an expert on these vehicles I could visit. Thank you. Quote
0 fuzzo Posted August 27, 2012 Posted August 27, 2012 i had a miss in my gdi and that was from the gdi pump malfunctioning i took it to my garage and got it cleaned out and it's working fine. Quote
0 Magnum357 Posted August 28, 2012 Posted August 28, 2012 (edited) GDI engines have one coil each for every spark plug. If one of those coils malfunctions then too the engine developes a miss and the pulling power is also reduced specially under load such as going up on an incline . I had the problem and changed the defective coil and it worked fine thereafter. Edited August 28, 2012 by Magnum357 Quote
0 fuzzo Posted August 28, 2012 Posted August 28, 2012 (edited) garage i took it to was called technodrome. its off baseline road. call Dileepa on 077 742 5123. he will be able to help you out Edited August 28, 2012 by fuzzo Quote
FastCar
Thank you.
6 answers to this question
