This is just a suggestion. First we might discuss that whether it is useful or not, any hidden problems etc…
Suggestion: members would post following information regarding the vehicles they own, latter if our member need some reference to compare some parameter related to vehicle(probably when we feel that our vehicle has some problem) then members can use this thread. If we can follow a common format then we can use some software tools to extract these data if it is necessary.
But the relevant vehicle should be in good condition (that means there is no point of posting information related to which has heating problem or misfire)
What kind of information:
Meta information: Vehicle make, YOM, model (should be specific, ex: even though impreza is a model name, it will not help us), engine capacity, AT or MT or TT, variant related information.any MODs you have done
Parameter: Based on last vehicle emission test ,all parameters specified in emission test result sheet,
If vehicle has RPM peter, then IDLE RPM when engine is not reached to operating temperature (morning start).
Engine Temperature meter position when it is saturated (as a percentage, ex: 50%)
