March 23, 201511 yr There are places who do a better job at it than others.As VVTi said the place I go to has this whole baking process.Up untill now never had a single failure.What you say is true.If it's your family car it's always better to go for new ones.For me it makes sense cos for the lorries when I add everything I get a significant saving. Refurbishing pads should be left for pads that are hard to get or unavailable locally. Not for pads that are available, even at a higher cost. These are brakes after all. The reason I agreed to get the Alfa clutch plate refurbished was the info given by the local 'experts' claiming Alfa clutch plates are Unicorns. Later once the deed was done, I managed to source them for 1/3rd the price quoted by the locals.
March 23, 201511 yr My opinion is that regardless of how well the bonding has been done, if the friction material used is too abrasive, then the pads will wear out the rotor sooner. That's quite similar to using substandard aftermarket brake pads. So if OEM pads/shoes are available, then it's always safe to use them. If we look at overall performance , safety and durability yes its right. However when it comes to business vehicles the perspective changes. Most of the cases the brakes will worn out in 3,4 months and required replacement. Thus the cash flow, time value of money, etc plays bigger role comparing to our car. From business point of view, if they hope to use the vehicle for 2 years and it required 5 times brake pad/shoe changes. They might spend 1/10 of the cost for those 5 changes and end up with worn out brake rotor/drum after 2 years. So they sell it and move to another vehicle. Edit - Not that I say this is the right thing to do. But There is a business line built up just like re-boring, re-filing worn out CV joits, bushes, etc, for a vehicle used solely for business it makes more sense. Edited March 23, 201511 yr by MkX
March 23, 201511 yr My worry in terms of brake liners is them coming off and then causing the wheel to jam. This just happened to a guy in the Ratsun forum the other day while at 70mph at a motorway. Only sheer luck and skill had avoided a serious accident. In my car the liners had come off (must have been low quality replacements), but on one side they stayed attached. I would dread to think what might have happened if they had completely come off. I think in certain cases we have no choice. Either the parts are not available, ridiculously expensive. Also not all pads/ liners are the same quality (like the ones I clearly had) and sometimes you might even be better off getting them re lined vs buying new. They reline clutches and brake shoes even in the UK for the same reasons. Ultimately the key is knowing what you are buying I guess. Some people are going to do a better job than others.
