Hi All,
I'm having an issue with my A/C.
Sometimes it goes to "Auto" mode without me doing anything and no A/C at all.
I have tried to turn the A/C off. Then the text call "Auto" start to blink in the display.
After 10-15 mins A/C is on again. Seems like something wrong with the sensor, but I'm not an expert
so I thought someone in the forum might have come across a situation like this and will be able to help me out.
  • 2 years later...
This was caused by an actuator that is malfunctioning in the system. I also had the same issue and got the system serviced and got the actuator cleaned and serviced. Now It works ! If it does not work even after that, You have to replace the actuator
