Help.....climate Control A/c In Converted Kr-42
Does anyone know a good place around colombo to fix climate control A/C in my converted KR-42??It is converted to touch dual A\c but climate contrl is not working....And I also need a beige colour noah dash board (Dual Airbags,new model) with teak panels for speedo meter, dvd player and two front door switches of the same vehicle.If anyone knw a place pls leave a msg....
Your help in above matters r appreciated...
The problem you have if the AC is working is not something an AC guy is fixed. Basically when you fitted the dual AC system, what parts did you source? The climate control systems have a number of sensors used to regulate the temperature.
If its simply not adjusting properly check with the guy who installed it....
