I have a FB15 Ex-saloon 1500cc automatic transmission car (yom2000) and bought 2 years ago. I have done 8000km up to date and the car was stopped suddenly while driving on the road with “crees crees” sound. When the bonnet was opened by me, noticed that the belt connecting alternator was smoking. I have turned off engine and carried to the garage that was familiar me. Mechanic checked the engine, cooling fans, radiator.
The engine was raised by him and boiled up also fans were not automatically turned on. Again the engine was raised with directly connected fans and again boiled up. He told me, the engine’s gasket, thermostat sensor should be replaced and both parts were replaced with Nissan genuine after facing engine head. After replacing gasket & sensor, he told me, problem originated from faulty AC compressor because the engine was turned off automatically when AC switched on. Then AC compressor was replaced and the problem was solved partially.
But coolant was leaked out from water pump if the engine was raised with out direct fans (fans were turned on automatically via sensor. But it was not turned on before boiling starts). He checked water pump and told me, it was a good one. To day I have done 10km with directly connected fans & AC and noticed coolant was leaked out from water pump and top side of radiator (but radiator plastic tank is not faulty one). Then I raised directly connected fans, removing radiator cap. I noticed that no leaked coolant on water pump. Then I raised directly connected fans+AC, removing radiator cap. I noticed that no leaked coolant on water pump but the coolant was run out slowly from radiator tank opening.
Lahiru85
My dear friends, experts,
please help me to solve this problem.
10 answers to this question
