Anyone aware of somewhere where you can get the catalytic converter cleaner similar to the fuel injector cleaner that you can add into the gas tank for a euro car ? Alternatively is there someone doing Lucas injector cleaners or where you can buy a Chevron injector cleaner ?
Cheers,
Actually this is for a petrol car. Get this error that there is too much sulpher on the nox sensor. Apparently need to run the car for 100 kmph for 30 mins to clean it and preferably put in a cat cleaner or something.
Cheers,
Cheers,
Ok, none of the cleaners I cam accross I've seen in SL. Maybe this being SL and labour being cheap, taking the sensor off and cleaning it might also be an option.
