One of my friends having Toyota Cami Jeep, Auto 2001 module. One day he was telling me that he suspect that there is a gear changing issue in high speed and wanted me to have test drive.
I will put simply what I have observed. I figured that frm 1st to 4th gear change by sound (Nway D is 1st) and I reached 80Kmph and kept there for 1-2 Min's without moving the accelerator. The Rpm was 3500 and it didn't went up or down.
What I have observed with other cars I have driven is that in top gear at 80Kmph the Rpm was 2000. But here it's 3500.
So I doubt there is a issue in changing to top gear.
Also the Over Drive was on and when I offed it at 80Kmph Rpm went to 4500.
Could it be a normal situation or there could be a issue?
Other cars as of other similar make/model or just other other types of cars? If not similar make/model, you can't really compare rpm vs speed can you?
I do agree with you, tho it is not the same make and model, in general that is what I observed in several other vehicles.
Anyway please share your experience on this.
