Hi , i wish to buy a mitsubishi lancer cs1 2002 and it does not have power window . Does anyone know is it possible to change manual Winder system to power window without changing doors . Thank you .
Hi . welcome to the forum . i see you are a newbie hence you might have not searched the forum . its always good to search the forum and see if anyone has asked this question before instead of starting multiple threads with the same question . next time please do so :) .  This lancer power windows was discussed earlier and people who had the idea of converting to powershutter ultimately found it more easier to just swap the doors instead of hacking through doorcards. If you want to retain the original look then swapping the doors is easier because its hard to find only the doorcard and even if you find them they would be priceeeey . but then if you just want to move the windows with a button then a universal conversion kit is available that can be fixed to the existing manual window mechanism but it would definitely look ugly with the out of place switches and stuff instead of the original.
heres a thread about power windows that might help you .
