Djin Posted November 20, 2016 Share Posted November 20, 2016 Hi Guys, I recently bought my first car which is a fiat punto and i noticed that the generic warning light is always lit up, would anyone know what this means? I also would like to know the multimedia setup that existing punto owners have in their cars as mine came with a pioneer single dim setup and i am not happy with it. This is to see if anyone has replaced their system with an android touch system player. Quote Link to comment Share on other sites More sharing options...
fiatLife Posted November 20, 2016 Share Posted November 20, 2016 On 11/20/2016 at 12:49 PM, Djin said: Hi Guys, I recently bought my first car which is a fiat punto and i noticed that the generic warning light is always lit up, would anyone know what this means? I also would like to know the multimedia setup that existing punto owners have in their cars as mine came with a pioneer single dim setup and i am not happy with it. This is to see if anyone has replaced their system with an android touch system player. Expand can you post a image of the warning light? Quote Link to comment Share on other sites More sharing options...
Djin Posted November 20, 2016 Author Share Posted November 20, 2016 As requested.... Quote Link to comment Share on other sites More sharing options...
fiatLife Posted November 20, 2016 Share Posted November 20, 2016 (edited) it should a burnt bulb as per the manual, check lamp bulbs The manual should state, Engine oil pressure sensor failure. Problem with parking sensors. Fuel cut off not available External light failure easiest is to check the external lights/bulbs for malfunctions Edited November 20, 2016 by fiatLife add more reasons 1 Quote Link to comment Share on other sites More sharing options...
NeroX Posted November 21, 2016 Share Posted November 21, 2016 Hi, Is this a diesel or petrol? The punto has a CAN bus system which checks intermittently for any electrical faults. This bulb lights up when it detects an error. Normally as soon as you switch on the odometer display it should tell you what to check. If its a bulb it'll say either "Check LHS/Brake Light" etc on the line just above the odometer reading. Most probably it is to do with a burnt bulb as fiatLife has mentioned. If its anything else another corresponding warning light should popup on the instrument cluster. In terms of the sound system, puntos came with an original blaupunkt CD/Radio. Yours seem to have an aftermarket facia/adapter modifying it to mount a standard single-din player. Only way to mount a double-din is to buy a corresponding double din facia. That would modify the two central AC vents to give you some space. OR you could buy a modified DVD player to fit the puntos dimensions. You could try searching on eb** or similar parts website. Cheers! 1 Quote Link to comment Share on other sites More sharing options...
Djin Posted November 30, 2016 Author Share Posted November 30, 2016 Thanks Guys. @fiatLife Yes it does seem like bulb issue. It is currently with Noel for some repairs and he made the same diagnosis. @NeroX This is a diesel machang.I do not want to significantly alter anything by changing the air vents. However, when i browsing the fiat forum, i came across a post where i guy had fixed a single din android system which bluetooth, GPS and rear camera functions. The below was the product he had used. Do you or anyone have any experience with these? http://www.aliexpress.com/store/product/Android-Car-DVD-GPS-for-Fiat-Grande-Punto-Linea-with-Bluetooth-Radio-RDS-Wifi-3G-Mirror/912113_32585438228.html?spm=2114.8147860.0.75.I3K9ue Quote Link to comment Share on other sites More sharing options...
