hi all,
I need to troubleshoot my 4dr5 jeep brake system. I decided to isolate all brake Lines one by one. I found there is item to do it. Called as brake line end caps. Anyone knows a place to buy theM?
thank you
Edited by VishwaR
clarification
In brake lines the thread follows the British Standard Pipe (BSP) threads most probably in Japanese and European vehicles, not the normal  metric/ inch thread format . The American analogy is NPT (National Pipe Thread) but not compatible with BSP.
You may use a bolt of 1/4" BSP thread at the brake hose end to lock each end, if available or  lathe a bolt to the said specification.
