This is not because hybrids don't do bad emissions but because of our testing centers do not have a way to keep engine running while doing tests.
AFIK you can plug a scan tool to OBD port and manipulate engine throttle and run engine as a regular engine to perform tests.
Also in toyota hybrids, there is a hidden sequence to enable maintenance mode too [1] which will run it as a regular car without stopping engine.
[1] http://carspecmn.com/putting-your-toyota-prius-into-maintenance-mode-getting-the-engine-to-stay-running/
