January 27, 20179 yr I replaced the clutch of my 2005 Suzuki Marutiย Zen a few months back from a local joint and the costs were as follows: Clutch + pressure plate kit - 5300/= (Brand: Valeo) Throw-out bearing - 1300/= (Brand: FBJ) Labour charge - 2500/= which totals to 9000/= A*W quoted me something close to 15k as far as I can remember. The cost for your Alto should be similar or slightly higher. If you have the time to spend and know a good mechanic, getting it done through a mechanic can save you about 6k. The genuine brands for Suzuki Maruti Zen were "Valeo" and "CeeKay", not sure about Alto though. Get the pressure and clutch plate as a kit if possible. Do a search on team-bhp forums and you can find a lot of info related to your question. While you're at it, get your flywheel and pilot bearing inspected as well.
January 28, 20179 yr Author 23 hours ago, Vengeance said: I replaced the clutch of my 2005 Suzuki Marutiย Zen a few months back from a local joint and the costs were as follows: Clutch + pressure plate kit - 5300/= (Brand: Valeo) Throw-out bearing - 1300/= (Brand: FBJ) Labour charge - 2500/= which totals to 9000/= A*W quoted me something close to 15k as far as I can remember. The cost for your Alto should be similar or slightly higher. If you have the time to spend and know a good mechanic, getting it done through a mechanic can save you about 6k. The genuine brands for Suzuki Maruti Zen were "Valeo" and "CeeKay", not sure about Alto though. Get the pressure and clutch plate as a kit if possible. Do a search on team-bhp forums and you can find a lot of info related to your question. While you're at it, get your flywheel and pilot bearing inspected as well. many thanks its not my personal one but use it for business ,its a alto lxi (2013) ย
