1 answer to this question
You can find a well maintained Fit Area.But most of the Vios'es around here are abused.Vios is from thailand and Fit aria is from japan.Fit aria is famous for its Cvt gearbox issues,while Vios has a conventional Auto which is proven to be solid.Also the engine in Vios is the same thing you find in 121,Allion and Premio 240 and 260,Axio so maintainence might not be a problem.One of my father's friend has a Fit Area which has been using for about 6-7 years without an issue under extremely light usage as a second car.Both are good on fuel.Vios might be good at acceleration while Honda might provide you with better comfort.Vios has a bit hard ride.
