About toyota lanka full inspection
My father going to buy a used car and we want to check before buy it.what about the toyota lanka full inspection? What are things we can get from that,?
And also what are the other places we can inspect with all the details (like toyotalanka inspection) near kandy?....Thanks
Sent from my [device_name] using http://AutoLanka.com mobile app powered by Tapatalk
6 answers to this question
I don't think they will find every fault with your vehicle specially the under body accident repairs. Therefore it is better that you use a trusted mechanic as well. However, the inspection will give you a fairly good picture of the vehicle if it done correctly. It is better than nothing.
Thanks for your advice.Do you know about other places that doing same inspection as toyota lanka ??
Take the car to 'C*r Ch*cks' in Kohuwela. They are quite good in what they do. You can check them out on FB before going. The price you pay for the inspection is worth it because they will give you a comprehensive report which would come in handy, incase you do end up buying the car. Cos you'd know what needs to be looked in to after buying. Good luck.
There's a place in Nugegoda called D* S*l*a. I don't know whether they have any branch in Kandy.
Thanks for the info.but seller doesn't like to came such a distance without advance.so am looking for place in kandy...[emoji4]
