Hi Fellow members;
Im in need of great assistance. Ive been running an Nissan Cefiro A33 YOM 2000.
the vehicle has been well maintained but recently i have encounter a gear box issue
Scenario: When in the morning I start the vehicle and Change the Gear to 'D', the vehicle doesn't move and so Does 'R'.but after the engine is heated I change the gear to '2' and keep accelerating couple of time then this is a *DOKKK* sound from the gear box(Sounds like forced to be released) and then releases the gear at '2'. and while driving on '2' after reaching a speed limit of 60 KMPH and shift the stick to D the gear works perfectly(3rd gear shift). But if i stop and reverse it comes back to be forced to accelerate and then the DOKK sounds comes and vehicle moves.and over again i have to Shift to Gear 2 and do the same again.
Can someone advice me what is the issue and how this can be rectified.
  only 110,000 KM DONE
Would be of great assistance.
3 answers to this question
Most probably your forward clutch is gone. Show it to Chandana or Nilwala motors (0773027118)
Sent from my [device_name] using http://AutoLanka.com mobile app powered by Tapatalk
On 4/10/2018 at 12:51 PM, BunnyBoy said:
Hi Fellow members;
Hi.... I also have faced the same problem recently on my cefiro and seeking a help. If you see this post please contact me on 071 620 8458. Did you fix the problem? From where? How did it cost you. I am waiting for an answer call from you dear.
