I have vezel 2015. I am getting smart key warning message since few weeks. I have change the smart key battery also. And checked with the spare key as well. This is coming after long drive and switch off and switch on the engine. May be when the the engine hot. If i keep to cool down and try key warning disappear. All the equipment are works fine. Any body face this issue. I have read lot of articles about this. some persons has mentions smart key system relay was the issue and getting this error when got heat. They have mentioned after replacing relay issue fixed. some persons mentions problem with push starter button. I have heard the same issue before. Replacement and cost will be around 35000. But some persons havent replaced the butter. they have clean the push starter button from contact cleaner and issue fixed. Can you guys share your experience with me.  Any place to repair.
1 answer to this question
