Dear Experts with my all the respect,
In my car ( carina at 192) I feel like torque is not delivered when needed. In a road with inclination upward I feel the car is less torque and raising more than it should be ( i.e. it raises around 2 - 2.5k) and changes to a gear which is also seems less power.
I checked how to test whether the gears are shifted properly and did following test based on my car manual.
1) get a voltmeter connected to TT (+ve) and E(-ve) in diag socket.
2) get the reading while I am driving.
3) The voltage values at different gear positions are in attached pic below.
4) Problem is when I drive I only (even in flat or inclined roads) get  0v, 2.1v, 4.1v and 6.1v. I could not obtain higher value than 6.1v since I did not test it in a highway.
5) For an example at gear upshift 0v -> 2.1v -> 4.1v -> 6.1v.
6) My problem is, as per below table I should get some voltage near 1v as well since its the second gear. This value is hardly given when I drive very slowly ( <10kmph). But Other times I am not getting the second gear.
Is it normal? Cant the car get shifted to second gear if i need more torque in a hill ?
PS - the letter  B in the picture is for letter V. (Volts).
0 answers to this question
There have been no answers to this question yet
