19 minutes ago, Nisa said:
I have Aqua 2012 car. today mornig when its start its on and ready mode. but gear cant change. its lock. pls help
Did you try to unlock it by manually? If it possible and then you can run the car, the problem could be on lock releasing. Please check it.
Maybe a problem with the shift lock system. you can try by pressing the shift lock override button. The shift lever can be shifted while the button is pressed.
Yet you will have to get it checked by a service agent.
Edited by amsandun
