I would need to get compression test done on a Ford Laser (carb model) as its smoking,my mechanic feels its just the valve seals and the compression is good however before I get down to getting it done I would like to get a compression test done
Do you know any place in Nugegoda,Dehiwela,Kohuwela,Mt lavinia or Ratmalana where I can get this done and the approx cost
An engine compression test will tell you many things about the mechanical condition of your engine. The test can detect, for example, pressure leaks through rings, cylinders, valves, or a head gasket without taking apart the engine. So you'll save a lot of time and money in diagnostics.
