​ Welcome Forum Guest! 👋 ​
Toyota passo
The problem can be related to wheel alignment/ balancing. Get your wheels checked from a good workshop. My fathers wagon had a similar issue, then he swapped the front & rear wheels and problem got fixed more or less. Still recommend doing a proper wheel balancing/ alignment correcting from a good mechanic.
Had the same problem
First of all its because of alignment or wheel balancing
If that one is already done than
You must need to check the axle
