Hey there... i’m here for vanette c22 fuse box diagram, i just checked the fuse box I couldn’t get it right, as it showing numbers 1 to 20 and one side is on other is just off.. ??
if anyone could explain me the diagram clearly would be a great help!! Thank you..
i’m attaching picture of fusebox here ??
3 answers to this question
Just seen this, here is the vanette  C22 fuse box layout for Diesel models.
Original Fuse Amp rates are here too.
If you need any further details refer the below diagram.
Edited by Cyclist
Thank you ? Cyclist..
I’m experiencing an sudden engine stop while on run, so i checked with mechanic and got to know that alternator won’t charge the battery.. recently alternator got serviced and was running fine. Day before yesterday when i was on run again same problem came up.. now I’m confused what can be the actual cause???
As I’m a learner on vehicle mechanisms please some one explain me why this is happening!! i have checked and changed all the electronic parts which are;
* distributor serviced and platinum point replaced
* new bottle coil replaced (which they recommend is original for this vehicle)
* new ngk plugs
* engine timing checked
* alternator serviced
Engine has a carburetor which is in running condition and other electrical equipment all checked.
still I can’t find out why this is happening ?
all of a sudden van getting stop, after few minutes it starts again runs normal.
