athula kumara Posted July 30, 2021 Posted July 30, 2021 (edited) Hello when running care on the mountain has been mix therefore i was scan my car & indicate two fault 1.crank sensor 2.coli Already replace 3 coil & crank sensor but again re indicate the check engine bulb & mix can you give me the instructions Thanks Br Athula Edited July 30, 2021 by athula kumara Quote
