January 14, 200719 yr hey guys its me sida here..(new to the club) jst wondering weather our civic eg8 ecu's comes wit a removable chip base. coz i saw some ecu's on web which they have a removable ecu base where we can have sevaral programmed chips and can plug it in when ever we want easily than gettin it to programmer and gettin the shit out of it. and also i found out that there a pre-programmed chips to get and plugg-it in (if ve a base).. hey i ve some ecu codes as well for 92-95 civic eg8 VTEC.. mit be useful for any1 there... Here is the information you need to read error codes on 92-95 Civic and Del Sol (CRX). Those cars are OBD-I, so the same info should be usable for any other OBD-I Honda. I have not had interest in other Honda cars, so i don't know what year Accords and Preludes are OBD-I. Anyway, off to instructions. There is a 2-pin (most likely green in color) connector by the ECU or somewhere under the passenger's side dash. It's a Data Link Connector. Connect it's two pins with a piece of wire. Watch out not to get jolted while you're connecting the pins. You will read error codes on the gauge cluster, on the Malfunction Indicator Lamp. Turn the key to position "II" and watch the lamp blink. Error codes are reported by a number of blinks. There are short and long blinks. Long blinks mean 10, and short blinks mean 1. For example, if you get "long-long-short-short-short", it means error code 23. There is a short pause between each flash (long or short) and a long pause between 2 error codes. There will always be long flashes before short flashes. So you cannot expect number 23 to be reported as "short-long-short-long-short". Take note of all error codes reported by ECM (Electronic Control Module). Find a list online that explains "OBD-I error codes honda" and you will find out what your problems are. Do not forget to remove the wire from the 2-pin connector once you are done. Here are the trouble codes: 0 Bad ecu (if cel is on and no code or light stays on) 1 O2A - Oxygen sensor #1 2 O2B - Oxygen sensor #2 3 MAP - manifold absolute pressure sensor 4 CKP - crank position sensor 5 MAP - manifold absolute pressure sensor 6 ECT - water temperature sensor 7 TPS - throttle position sensor 8 TDC - top dead centre sensor 9 CYP - cylinder sensor 10 IAT - intake air temperature sensor 12 EGR - exhaust gas recirculation lift valve 13 BARO - atmospheric pressure sensor 14 IAC (EACV) - idle air control valve 15 Ignition output signal 16 Fuel injectors 17 VSS - speed sensor 19 Automatic transmission lockup control valve 20 Electrical load detector 21 VTEC spool solenoid valve 22 VTEC pressure valve 23 Knock sensor 30 Automatic transmission A signal 31 Automatic transmission B signal 36 traction control found on JDM ecu's 41 Primary oxygen sensor heater 43 Fuel supply system 45 Fuel system too rich or lean 48 LAF - lean air fuel sensor 54 CKF - crank fluctuation sensor 58 TDC sensor #2 61 Primary oxygen sensor 63 Secondary oxygen sensor 65 Secondary oxygen sensor heater 71 random misfire cylinder 1 72 random misfire cylinder 2 73 random misfire cylinder 3 74 random misfire cylinder 4 80 Exhaust Gas Recirculation insufficient flow detected 86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem 90 Evaporative Emission Control System leak detected in the fuel tank area 91 Fuel Tank Pressure Sensor low input 92 Evaporative Emission Control System insufficient purge flow TC bye
January 14, 200719 yr Yes EG8 Ecu's (P.08) do have a removable chip base. Welcome to the site man.. When your taking info off other web sites.. always good to be polite and give the original author the credit by adding the link/source. Preprogrammed chips have their merits and demerits as every car's setup is different and will need to be tuned accordingly using a dyno, AFR etc. And its very easy to find a link:) http://www.askmehelpdesk.com/cars-trucks/r...ndas-18139.html
January 14, 200719 yr Yes EG8 Ecu's (P.08) do have a removable chip base. Welcome to the site man.. When your taking info off other web sites.. always good to be polite and give the original author the credit by adding the link/source. Preprogrammed chips have their merits and demerits as every car's setup is different and will need to be tuned accordingly using a dyno, AFR etc. And its very easy to find a link:) http://www.askmehelpdesk.com/cars-trucks/r...ndas-18139.html Nice work Sherlock!
January 16, 200719 yr welcome bro !!! as pila said ... 92-95 eg8/eg9 comes with external chips supported. there r few things to get the job done i think.
January 16, 200719 yr welcome bro !!! as pila said ... 92-95 eg8/eg9 comes with external chips supported. there r few things to get the job done i think. I never new there was a EG-9???
January 16, 200719 yr I never new there was a EG-9??? http://en.wikipedia.org/wiki/Honda_civic#F....281992-1995.29 probably means the EH9. Damn, never knew the Civic had a 3.0l V6. I'm wondering if thats a joke or summin, coz the english in that sentence sucks.
January 16, 200719 yr Author Yes EG8 Ecu's (P.08) do have a removable chip base. Welcome to the site man.. When your taking info off other web sites.. always good to be polite and give the original author the credit by adding the link/source. Preprogrammed chips have their merits and demerits as every car's setup is different and will need to be tuned accordingly using a dyno, AFR etc. And its very easy to find a link:) http://www.askmehelpdesk.com/cars-trucks/r...ndas-18139.html hey bro really sorry for not telling that i took the codes and things from a site, i really took this long time back as i bought my EG8 to find out a sensor error. and it was in a word doc which i had saved. so i really couldnt remember the site. just thought it mit be useful for the guys out there coz i know that some doesnt know how to check the error codes and i was reffering to them. also many thanks for letting me know that the ecu has a chip base. then can proceed wit the further investigation on the research.. he he he looks like a dam cop movie words nee.. he he he anywayz..... c ya ve some pics uploaded on the autolanka meetup mit wanna check it out. http://www.flickr.com/photos/unzip2000/ thanks out of da house -sida- welcome bro !!! as pila said ... 92-95 eg8/eg9 comes with external chips supported. there r few things to get the job done i think. thanks for the info bro... coolz to meet u guys ... out of da house -sida-
January 16, 200719 yr http://en.wikipedia.org/wiki/Honda_civic#F....281992-1995.29 probably means the EH9. Damn, never knew the Civic had a 3.0l V6. I'm wondering if thats a joke or summin, coz the english in that sentence sucks. mmmm... if i'm not mistaken all domestic 92-95 civic SIRs refered to EG9 http://english.auto.vl.ru/catalog/honda/civic_ferio/1993_9/ @Rily There are .. check out the site Edited January 16, 200719 yr by Thusha
January 16, 200719 yr http://en.wikipedia.org/wiki/Honda_civic#F....281992-1995.29 Damn, never knew the Civic had a 3.0l V6. I'm wondering if thats a joke or summin, coz the english in that sentence sucks. I think thats a mistake.. C30's came in NSX's.. a rear wheel drive 5th Gen Civic?? nope dont think so..
January 16, 200719 yr EG-9 is the 4 door SIR, same body shell as the EG-8 but with a B16A series 2 motor. C series also came on the Legend but never on a civic.
January 17, 200719 yr Author machan, could any1 tel me wats the Vtec crossover range in a honda eg8 stock ecu and the rev limit of the stock ecu as well? thanks out of da house -sida-
January 17, 200719 yr machan, could any1 tel me wats the Vtec crossover range in a honda eg8 stock ecu and the rev limit of the stock ecu as well? thanks out of da house -sida- 7200ish is the rev limit..cross over at about 4800 if I'm not mistaken. Its around 5800 in the 3stage.
January 19, 200719 yr 7200ish is the rev limit..cross over at about 4800 if I'm not mistaken. Its around 5800 in the 3stage. true, according to the spec .. its 4800,
January 20, 200719 yr Author 7200ish is the rev limit..cross over at about 4800 if I'm not mistaken. Its around 5800 in the 3stage. thanks alot mate.. cheers out of da house -sida- true, according to the spec .. its 4800, thanks alot for the info mate.. out of da house -sida-
