what is this Terraclean????
What is TerraClean?
TERRACLEAN™ is a new and revolutionary way to clean your car’s engine and restore it to peak performance. This patented process combines breakthrough technology and science to clean more efficiently than any other chemical-based product or gas tank additive. The service can only be performed by a trained professional, and is available at selected service centers in Canada and the U.S.
TERRACLEAN™ is very different from all other chemical cleaning agents on the market. It cleans the complete fuel system, does not damage any engine components, takes effect much quicker, and most importantly does not emit any noxious fumes!
Essentially, TERRACLEAN™ is a specially formulated fuel that is distributed in small canisters to service centers that offer the TERRACLEAN™ service. It works by first processing the fuel through a special unit that negatively charges the molecules before entering your engine. Your car then runs on TERRACLEAN™ fuel while cleaning your entire fuel system, which helps remove years of unwanted carbon build up (engine residue) from your cars various parts and components.
The benefits of this superior technology are numerous. A TERRACLEAN™ engine is proven to improve fuel efficiency, significantly reduce emissions, and improve performance. This means that you SAVE MONEY by getting better gas mileage out of your car and as a result, the TERRACLEAN™ treatment will pay for itself in the long run. It is also proven to help you pass an emissions test immediately after the treatment, and at the same time help reduce exhaust fumes that are harmful to the environment
http://www.terraclean.net/home.html
