Engine Mount Connection Broken - Please Help..
HI ALL,
In my Fb15 i have a problem such that, the place whare the front engine mount connect to the engine has broken . Currently engine connects to the front engine mount by two bolts. But the lower bolt has broken from the place where it connects to the engine. When i took it to a guarage the guy said, sir you can weld it and run for some time, and he said if you want to get it done at A*..W agent they will just replace the entire engine cover and it will cost around 100K.
Guys it it true that we need to replace the entire engine cover. :unsure: Is welding work will be egough for long run of the vehicle. Has any body experiences such a proble. Please help me on this matter. Fortunately still the vehicle does not create any problem for me (such as vibrating). What shoul i do here ? expect your valuable ideas please..
i have attached a image of the damage..
http://img243.imageshack.us/my.php?image=dscn0515sv2.jpg
1 answer to this question
If the upper bolt is ok- then welding the lower one should sort you're problem as these bolts are normally pretty strong and dont let up.. it maybe a good idea to get the job done at a Pattalaya as you will need electric welding & as this a specialist job.
