2006 BMW 325 Ci Coupe M Package
Year 2006
Make BMW
Model 325 Ci Coupe
Engine Location Front
Drive Type Rear Wheel
Weight 3197 lbs | 1450.2 kg
MPG City 20
MPG Highway 29
Performance
0-60 mph 7.1 seconds.
Top Speed 128 mph | 206 km/h
Engine
Engine Configuration I
Cylinders 6
Aspiration/Induction Normal
Displacement 2.50 L | 152.6 cu in. | 2501.1 cc.
Horsepower 184.00 BHP (135.4 KW) @ 6000.00 RPM
Torque 175.00 Ft-Lbs (237.3 NM) @ 3500.00 RPM
HP to Weight Ratio 17.4 LB / HP (Vehicles with similar ratio)
HP / Liter 73.6 BHP / Liter
Bore 3.31 in | 84.1 mm.
Stroke 2.95 in | 74.9 mm.
Compression Ratio 10.5 :1
Fuel Type Gasoline - Petrol
Any reviews on this car? tech tips etc.....
Hello Dillon,
I don't have any tech tips on this ride - but, I do have a review. I've driven a 2004 330ci, and it was a blast! When you take it around a curve and goose the throttle, the back hunches down and pushes the car through the curve (as long as you don't induce too much oversteer). I could only imagine that the 325ci is similar. As for techy tips, I'd turn that over to Lalithster... any comments?
Chris
