1 answer to this question
15 hours ago, Kaveen Dakshitha said:
What to look for when you are buying a nissan hb 12 station wagon diesel
Diesel swaps were a common practice in the 90's so first of all check if the car was an original diesel.(even if it was not - a proper swap will not be an issue but advised to practice caution)  I'd assume the engine is an CD17 if it were original. Check for the usual, check for blow by (google for it), check if the vehicle pulls well, gear shifting. Ideally get a diesel mechanic to check it. When it comes to body the usual checks need to be done : corrosion, interior etc.
