Charith Posted December 3, 2007 Share Posted December 3, 2007 No commentary http://www.youtube.com/watch?v=akFMs90a8Rw So.... what's your reaction? I'm smiling Quote Link to comment Share on other sites More sharing options...
Velocity Posted December 3, 2007 Share Posted December 3, 2007 Charith said: No commentary http://www.youtube.com/watch?v=akFMs90a8Rw So.... what's your reaction? I'm smiling WTF...... Has the 4B11 met its fate.... Quote Link to comment Share on other sites More sharing options...
evilmak Posted December 3, 2007 Share Posted December 3, 2007 (edited) Charith said: No commentary http://www.youtube.com/watch?v=akFMs90a8Rw So.... what's your reaction? I'm smiling Hold your horses until Mitsu sort out the issue with SST box! If you watched the movie carefully (like Mivec.Turbo very correctly observed and pointed out ) the IX took the advantage when SST X started short shifting after a while, which in fact is the exact problem with SST Mitsu is still trying to rectify. When the SST oil heats up, the computers go in to a short shift mode to save the gearbox (changes gears in lower rpms making the car slow). This is something even the motor journalists experienced while testing the X initially. Once they sort out this issue I am sure X will leave the pack standing or else as they say Darwin will be spitting on his grave. Edited December 3, 2007 by evilmak Quote Link to comment Share on other sites More sharing options...
JwesT Posted December 3, 2007 Share Posted December 3, 2007 evilmak said: Hold your horses until Mitsu sort out the issue with SST box! If you watched the movie carefully (like Mivec.Turbo very correctly observed and pointed out ) the IX took the advantage when SST X started short shifting after a while, which in fact is the exact problem with SST Mitsu is still trying to rectify. When the SST oil heats up, the computers go in to a short shift mode to save the gearbox (changes gears in lower rpms making the car slow). This is something even the motor journalists experienced while testing the X initially. Once they sort out this issue I am sure X will leave the pack standing or else as they say Darwin will be spitting on his grave. And also did u notice that Evo 9 and Sti 9 both understeer more than the Evo X. I think evo X needs bit more power Quote Link to comment Share on other sites More sharing options...
Charith Posted December 3, 2007 Author Share Posted December 3, 2007 evilmak said: Hold your horses until Mitsu sort out the issue with SST box! If you watched the movie carefully (like Mivec.Turbo very correctly observed and pointed out ) the IX took the advantage when SST X started short shifting after a while, which in fact is the exact problem with SST Mitsu is still trying to rectify. When the SST oil heats up, the computers go in to a short shift mode to save the gearbox (changes gears in lower rpms making the car slow). This is something even the motor journalists experienced while testing the X initially. Once they sort out this issue I am sure X will leave the pack standing or else as they say Darwin will be spitting on his grave. Doesn't explain why the 5-spd Evo X was slower. Quote Link to comment Share on other sites More sharing options...
mivec.turbo Posted December 4, 2007 Share Posted December 4, 2007 Charith said: Doesn't explain why the 5-spd Evo X was slower. Weight!! Quote Link to comment Share on other sites More sharing options...
evilmak Posted December 4, 2007 Share Posted December 4, 2007 Charith said: Doesn't explain why the 5-spd Evo X was slower. It was 'Salsa MR' driving the car!! Quote Link to comment Share on other sites More sharing options...
KLM Posted December 4, 2007 Share Posted December 4, 2007 Road & Track drove both cars (in standard form) back to back in Japan and apparently the X was faster by a good second and a half. Quote Link to comment Share on other sites More sharing options...
Charith Posted December 5, 2007 Author Share Posted December 5, 2007 evilmak said: It was 'Salsa MR' driving the car!! Yeah with a bird in one hand and a bottle in the other Quote Link to comment Share on other sites More sharing options...
madmax Posted December 5, 2007 Share Posted December 5, 2007 evilmak said: It was 'Salsa MR' driving the car!! Charith said: Yeah with a bird in one hand and a bottle in the other Are we missing out on something here? Quote Link to comment Share on other sites More sharing options...
darinwrxsti Posted December 5, 2007 Share Posted December 5, 2007 The evo x does seem to handle much better than the rest of the pack, however according to the spec i have no idea where all that weight came from 1520kg is seriously overweight for a road going rally car. i think everything is going to change when the sti comes out in march, been following its progress and its supposed to set the standard. will wait and see. Quote Link to comment Share on other sites More sharing options...
miniace Posted December 5, 2007 Share Posted December 5, 2007 The video is removed now... "This video has been removed due to terms of use violation" Quote Link to comment Share on other sites More sharing options...
MRM Posted December 5, 2007 Share Posted December 5, 2007 miniace said: The video is removed now... "This video has been removed due to terms of use violation" try this http://www.youtube.com/watch?v=9XzEvDckku8 Quote Link to comment Share on other sites More sharing options...
miniace Posted December 5, 2007 Share Posted December 5, 2007 MRM said: try this http://www.youtube.com/watch?v=9XzEvDckku8 Thanks Mate! That works! Quote Link to comment Share on other sites More sharing options...
GTAm Posted December 5, 2007 Share Posted December 5, 2007 Is there a weight difference between IX and X? Quote Link to comment Share on other sites More sharing options...
KaluZ Posted December 5, 2007 Share Posted December 5, 2007 http://www.edmunds.com/apps/vdpcontainers/...68/pageNumber=1 here is the blurb on the STI Quote Link to comment Share on other sites More sharing options...
Charith Posted December 6, 2007 Author Share Posted December 6, 2007 madmax said: Are we missing out on something here? Ah we're just talking about a mutual friend who drives an Evo VIII MR... and takes pride in his Salsa skills... hence the name Quote Link to comment Share on other sites More sharing options...
Velocity Posted December 6, 2007 Share Posted December 6, 2007 http://www.autoblog.com/2007/12/05/evo-x-v...kuba-lap-times/ t didn't take long for Japan's journalists to get the new STI and EVO X side by side, and the results are now officially in. Tsukuba circuit regulars Kazuo Shimizu and Manabu Kawaguchi spent an afternoon thrashing around the notoriously twisty short circuit just north of Tokyo and here (drum roll please) are the best times they could ring out of the AWD rivals: Mitsubishi Lancer Evolution X : 1:06:46 Subaru Impreza WRX STI : 1:05:95 So there you have it. The new engine placed further forward in the engine bay of the EVO X than in the EVO IX has indeed proven to be a handicap, while the STI's "wheel at each corner" longer wheelbase plus new double wishbone rear suspension has proved its worth. Neither car is quite as quick as its immediate ancestor though. Check out this 15 year rivalry of the EVO vs the STI as recorded at Tsukuba after the jump. [source: CAR Top magazine] Quote Link to comment Share on other sites More sharing options...
Grand Civic Posted December 6, 2007 Share Posted December 6, 2007 Velocity said: http://www.autoblog.com/2007/12/05/evo-x-v...kuba-lap-times/ t didn't take long for Japan's journalists to get the new STI and EVO X side by side, and the results are now officially in. Tsukuba circuit regulars Kazuo Shimizu and Manabu Kawaguchi spent an afternoon thrashing around the notoriously twisty short circuit just north of Tokyo and here (drum roll please) are the best times they could ring out of the AWD rivals: Mitsubishi Lancer Evolution X : 1:06:46 Subaru Impreza WRX STI : 1:05:95 So there you have it. The new engine placed further forward in the engine bay of the EVO X than in the EVO IX has indeed proven to be a handicap, while the STI's "wheel at each corner" longer wheelbase plus new double wishbone rear suspension has proved its worth. Neither car is quite as quick as its immediate ancestor though. Check out this 15 year rivalry of the EVO vs the STI as recorded at Tsukuba after the jump. [source: CAR Top magazine] Thanks for sharing this great informations... Quote Link to comment Share on other sites More sharing options...
GTAm Posted December 6, 2007 Share Posted December 6, 2007 Velocity said: http://www.autoblog.com/2007/12/05/evo-x-v...kuba-lap-times/ t didn't take long for Japan's journalists to get the new STI and EVO X side by side, and the results are now officially in. Tsukuba circuit regulars Kazuo Shimizu and Manabu Kawaguchi spent an afternoon thrashing around the notoriously twisty short circuit just north of Tokyo and here (drum roll please) are the best times they could ring out of the AWD rivals: Mitsubishi Lancer Evolution X : 1:06:46 Subaru Impreza WRX STI : 1:05:95 So there you have it. The new engine placed further forward in the engine bay of the EVO X than in the EVO IX has indeed proven to be a handicap, while the STI's "wheel at each corner" longer wheelbase plus new double wishbone rear suspension has proved its worth. Neither car is quite as quick as its immediate ancestor though. Check out this 15 year rivalry of the EVO vs the STI as recorded at Tsukuba after the jump. [source: CAR Top magazine] Great info. I really like the STi Impreza. And I think the hatch shape is perfect for the rally bred car that it is. Great to know it's quicker too. Quote Link to comment Share on other sites More sharing options...
Overdrive Posted December 7, 2007 Share Posted December 7, 2007 GTAm said: Is there a weight difference between IX and X? Eo X 1537 Kg vs the EVO IX 1310 Kg - 1400 Kg the MR being the heavier one. Quote Link to comment Share on other sites More sharing options...
GTAm Posted December 7, 2007 Share Posted December 7, 2007 Overdrive said: Eo X 1537 Kg vs the EVO IX 1310 Kg - 1400 Kg the MR being the heavier one. Aha so no surprise then that the nine smoked the ten on that straight! Quote Link to comment Share on other sites More sharing options...
Overdrive Posted December 7, 2007 Share Posted December 7, 2007 GTAm said: Aha so no surprise then that the nine smoked the ten on that straight! well actually the IX launched and the X did'nt. Does anyone know if the X (SST) comes with launch control? Quote Link to comment Share on other sites More sharing options...
Velocity Posted December 8, 2007 Share Posted December 8, 2007 http://www.nihoncar.com/review-478-X.html Here it is, finally and exclusively on NihonCar.com, one of or probably THE most anticipated Japanese sportscars matchup of the year: the everlasting battle between two kings of rally stages over the last decades; the Subaru Impreza WRX STi versus the Mitsubishi Lancer Evolution X! Over the past few years we had the privilege to test drive some pretty amazing and exclusive cars by each of those two manufacturers, for example the Impreza with the longest name ever: the Subaru Impreza WRX STi Spec-C Type RA-R produced at only 300 units and the excellent Mitsubishi Lancer Evolution 9 Wagon, only produced at 2000 units. Evos and WRXs always had their very own feel and character, making each one very easy to identify once behind the wheel but we also always struggled to designate a CLEAR winner in all those confrontations...the first thing you need to know here is that, once again, we had a hard time choosing which one was the winning machine. The second thing is: do these cars still deserve to be called "sportscars"? Don't worry, here come the explanations. Presentations Subaru Impreza WRX STI. The new Impreza has had a lot of people talking about it but not the way most would have imagined...the "questionnable" design was highly criticized but most were hoping for a better tomorrow thanks to the STi version which usually tops the sports range of the manufacturer. To "deserve" the STi designation, the new Impreza was fitted with a new aero bodykit including the usual front/rear bumpers, side skirts, rear spoiler and new exhaust. Under the bonnet lies a 2 liter Boxer 4 cylinders turbocharged motor producing something around 310HP (almost impossible to get the real figures without using a dyno) and 422Nm of torque. Lancer Evolution X. On the other hand, the "Beast" Evo X, was instantly acclaimed for its incredibly mean and aggressive style and the amount of new and impressive technology it was carrying mechanically. Unlike its "enemy", the Evo X receives a sporty treatment in the form of a raging bodykit including an enormous rear spoiler which fits right in. The interior got us pretty disappointed as Mitsubishi didn't prepare anything original, of course you're reminded here and there that you're inside an Evo, but the whole layout and equipments are coming straight from a "standard Lancer/Galant...we would have appreciated bigger ways to differentiate the beauty from the beast... Specifications Subaru Impreza WRX STI: - 4WD - 308 PS - 422 Nm (torque) - 1470 kg. Lancer Evolution X - 4WD - 280 PS - 422 Nm (torque) - 1420 kg (RS) WRX STI Versus EVO X, a match-up between two sporty family sedans. Such a title is probably having you wondering if you clicked on the right review but the facts are here, you cannot honestly consider those 2 vehicules as "sportscars" anymore but rather some "Sports Family Sedans". Technically speaking, both cars are faster than their own predecessor but most of what made each so famous seems to be gone...the kick in the *ss effect when you hit the throttle? Gone. The mind blowing braking abilities? Gone. The raging noise of the engine? Gone. The fun? Gone, The sensations? Gone. In order to give you the best, more fair and neutral point of view possible on both cars, we got our friend and pro race driver Nishihara-san to push these machines further than I ever could. Masaki is a 5 times All Japan Gymkhana champion and uses an Evo 9 but in a recent past, he worked with a WRX STi so he knows very well how to judge those cars. Here's a recap of what he had to say: Lancer or Impreza, his first reproach was the important gain of weight on both cars, close to a full 100kg more on certain versions. Second issue: the gearbox, it is the main reason why the cars fail to provide the thrilling acceleration it became famous for...on the Impreza the ratios are simply way too long while on the Evo the grid is too wide. His words on the Impreza now: Apparently, the Double Wishbone suspension wasn't well tuned and the car isn't balanced the way you'd ideally like, as a result, it can be tricky to drive. Oversteer on one hand and understeer on the other, that's what you'll get with the stock suspensions if you feel like going for a "dynamic ride". Another problem with the suspensions is the lack of comfort but that's something that potential buyers know and are ready to deal with. Below 4000rpm, the WRX STi feels just like your average Impreza and when you cross that limit, even thought you can climb up to almost 8000rpm, you always feel that this is a 1470kg car (3234 lbs). About the Evo: We agree to say that the Evo looks better but the whole picture is far from perfect here as well. The weight is, again, a problem . 100kg more than the previous Evo, 1420kg and a 4 cylinders 2 liter turborcharged engine to move this big baby. Behind the wheel, the Evo is more fun to drive, the boost kicks in at 2000rpm and the precision of the steering and the AWD system makes the ride much more enjoyable, as a result the driver feels more confident and can keep on pushing. Conclusion: Do you remember the VW Golf GTI which, generation after generation was trading performance for comfort (until things changed for good recently again)? Well it now seems that our 2 beloved Japanese car manufacturers are hit with the same disease. The best example has to be the "ECO" mode on the Impreza WRX STi, it has the ability to turn what is commonly known as a sportscar into a snail. We, at NihonCar, are huge fans of the Evo 9 and Impreza RA-R and this is why we have been very disappointed by those two new generations which seem to slip down the hill to feel more and more like a Lexus minus the real interior comfort. If we had to choose, we'd pick the Evo X because the handling and style are better. I could only recommend the fans to stick to their Evo 9 or WRX STi 2006 until Ralliart or Subaru prepares something really worth it (2008 RA-R??). Maybe the major tuners (Mine's, Top Secret, HKS...) will show them the way but don't get us wrong, those are good family cars offering sweet sensations...just not what we expected really. Posted on 07/12/07 By G-A.G Quote Link to comment Share on other sites More sharing options...
Velocity Posted December 10, 2007 Share Posted December 10, 2007 Damn this pic keeps me drooling all over. Quote Link to comment Share on other sites More sharing options...
