Guys, I recently bought a Nissan Sylphy G11 2005 as my first car. It was fine when I did a test drive, but after I bought it, I took it to a service station (my bad for not going to the dealer) and did a regular service. When they emptied the engine oil there wasn't much oil and it was dark coloured. The previous owner said he used 20w50 oil so I used the same during the service. However, after I returned from the service, there was a significant hesitation in the engine, which even stopped on a small hill. Once I started again and revved a little it was kind of okay. At this point, the check engine light was lit and the code was P0171 lean condition.
So after this, I took it to A*W and they suggested doing a tuneup. I did it from A*W and they replaced the spark plugs and also discovered there was a heavy sludge formation. They removed the valve cover and cleaned most of it by hand and suggested changing oil in shorter intervals. They also recommended to change the injectors as they were kind of damaged. So once I returned from A*W the pulling power was good on the engine but right on the next day the CEL came on again and the performance was kind of bad again. It was again a lean condition. After this, I did the below,
- replaced injectors with refurbished ones (didn't fix anything)
- replaced the oxygen sensor (was really good right after it was changed but went back to the same problem in a couple of hours of driving, live data scanned shows proper values )
- started to use 95 octane petrol (slight improvement in the performance and responsiveness, somehow the P0171 code is now gone the CEL is not lit and there are no other error codes)
- replaced the fuel pump motor (had a significant improvement in cold starts and pulling power)
- replaced air intake manifold gasket (no improvements)
But still, the hesitation is there. it's most noticeable when I fully press the accelerator, it starts with a wired low rumbling sound and the sound goes away after it picks up rpms. And sometimes the engine revs around 3000 rpm but doesn't pull the car enough relative to the rpm. I have also noted during this time the rpms increase incrementally like a little bit and a little bit and not smoothly and feels like the engine is trying to push away air. However, on high gears, the performance is really good and I can cruise around 100 easily.
Recently I did a break service at automiraj and when they lifted the car we saw there was a small hole in the resonator in the exhaust line. Not sure if this is the cause for that.
Has anyone had any similar experiences? I'm really fed up with going to makabasses because no could identify the root cause.
I would appreciate if anyone could give any ideas about probable causes.
Officially joined the thel-hinganna normie horde with ....drumroll... a 2025 Vezel... I am eagerly anticipating joining the 'thel keeyak karanawada' debates at almsgivings.
Recently, got the opportunity to see and get inside of The one and only Japanese V12, Toyota Century(a.k.a Japanese Rolls Royce). Is it really upto Rolls Royce standards? Nope, I don't think so. Items like Switches and mirror housings are in plastic. But, we can be assured that the dashboard will not light up like Christmas and would run forever....
nkt
5 answers to this question
