May 7, 20251 yr Hey guys, recently got an FK6, and the battery is on its last legs as per the check up done - the shop I usually visit told me that you can run it for 3-6 months. What's a the proper battery for a 2017 Honda Civic FK6 (EX)? I believe it requires some special battery due to the auto start/stop.
May 8, 20251 yr 13 hours ago, Noobdriver said: Hey guys, recently got an FK6, and the battery is on its last legs as per the check up done - the shop I usually visit told me that you can run it for 3-6 months. What's a the proper battery for a 2017 Honda Civic FK6 (EX)? I believe it requires some special battery due to the auto start/stop. For the stop start to work you need EFB batteries. My FK6 originally came with a Varta battery that lasted 4 years. During the fuel crisis in 2022 mine packed up and I was unable to find an EFB battery - there was a huge problem with supply chain back then as well- I ended up getting a Yuasa without EFB. It packed up in 2 years.ย Currently I'm running an Amaron AGM (60mah) - so far no complaints. Cost me around 50K. The EFB batteries come with one year warranty as opposed to two.ย
May 10, 20251 yr Author On 5/8/2025 at 3:46 PM, matroska said: For the stop start to work you need EFB batteries. My FK6 originally came with a Varta battery that lasted 4 years. During the fuel crisis in 2022 mine packed up and I was unable to find an EFB battery - there was a huge problem with supply chain back then as well- I ended up getting a Yuasa without EFB. It packed up in 2 years.ย Currently I'm running an Amaron AGM (60mah) - so far no complaints. Cost me around 50K. The EFB batteries come with one year warranty as opposed to two.ย Yeah, mines got a Yuasa right now too. You recommend the Amaron AGM then, yeah?
May 15, 20251 yr On 5/10/2025 at 8:15 AM, Noobdriver said: Yeah, mines got a Yuasa right now too. You recommend the Amaron AGM then, yeah? Yup. I really was not impressed with the Yuasa.ย
May 15, 20251 yr Author 7 hours ago, matroska said: Yup. I really was not impressed with the Yuasa.ย Thank you. Will get that in a week or two. Thank you so much. Is there any model code/specifics I need to look for when getting it?
May 16, 20251 yr 7 hours ago, Noobdriver said: Thank you. Will get that in a week or two. Thank you so much. Is there any model code/specifics I need to look for when getting it? Well if you just look for 60Mahwith EFB it should fit the bill. Let me check the model code I have and get back.ย
