October 23Oct 23 Frank’s 2023 FL5 Type R had that classic tucked-in factory stance, with the stock 19s sitting well inside the fenders, so he put 15mm spacers on the front and 20mm on the rear. Forget the looks for a second. The more interesting question is what keeps the wheel centered once there’s a spacer between it and the hub. On a bolt-on spacer, the hub does the centering, not the studs. We measured the FL5’s hub lip at 5.58mm up front and 7.36mm out back. The spacers are machined to the Type R’s 64.1mm center bore, so they pilot onto the lip with no play. That’s what keeps things smooth at speed. His hub measured 64.08mm against the 64.1mm spec. Frank’s car has racked up about 4,500 miles since January 20, including regular track days, with no problems. You’ll find the measurements, corner-by-corner photos, and his own comments in the FL5 Type R 4,500-mile write-up.
November 4Nov 4 On 10/23/2026 at 12:34 PM, EmmettWilder said: Frank’s 2023 FL5 Type R had that classic tucked-in factory stance, with the stock 19s sitting well inside the fenders, so he put 15mm spacers on the front and 20mm on the rear. Forget the looks for a second. The more interesting question is what keeps the wheel centered once there’s a spacer between it and the hub. On a bolt-on spacer, the hub does the centering, not the studs. We measured the FL5’s hub lip at 5.58mm up front and 7.36mm out back. The spacers are machined to the Type R’s 64.1mm center bore, so they pilot onto the lip with no play. That’s what keeps things smooth at speed. His hub measured 64.08mm against the 64.1mm spec. Frank’s car has racked up about 4,500 miles since January 20, including regular track days, with no problems. You’ll find the measurements, corner-by-corner photos, and his own comments in the FL5 Type R 4,500-mile write-up. This is interesting. Can you provide a bubble sort function in python?
November 5Nov 5 Author 18 hours ago, matroska said: This is interesting. Can you provide a bubble sort function in python? Nice try! I’m sticking to wheels and spacers, but I will say my bolt-sorting method is pure trial and error.
