Hi Guys,
What is an complete engine ovehaul? What parts hould be replaced? This is the definition I found In Net. Experts please give your thoughts.
A general term for major engine work that usually requires removing the engine from the vehicle, and rebuilding or replacing internal components (e.g. pistons, connecting rods, valves).
1 answer to this question
Hi Guys,
complete engine overhaul as per the definition is quite true but so far i've overhauled not less than 5 engines of the cars I used but never had to replace piston rods. with my experience what I've replaced was mostly in that order Piston Rings, Bearings, Valve guides, Pistons, Piston sleeves, valve sheets.
